Hey everyone.
Hopefully someone can help me with this. I am not getting power to the fuel pump with the key on. I have everything connected correctly and tripple checked everything. The only time the fuel pump energizes is when I initiate a start command and have the clutch depressed. Then the fuel pump will power on for a couple of seconds during the start sequence. (starter is disconnected)
I have good voltage for the trigger wire that goes directly from my ignition switch.
I have good voltage for the start wire that only is active when i press my start switch.
The PDB has voltage and I can hear the throttle body activate on ignition run. I have also verified the relay at the PDB is working and jumped the terminal to verify the fuel pump will activate.
Everything looks correct, however the PCM is not activating the fuel pump for some reason with key on.
I have not attempted to actually start the engine. Also the MIL light is not active with key on or start.
Any ideas?
