Thanks Thanks:  3
Likes Likes:  2
Results 1 to 12 of 12
Thread: Breeze PS Hose Kit Fitting Leaks
Threaded View
    Jul 2024
    BC, Canada
    This is not at all a knock on Mark at Breeze—he’s been very responsive and helpful—but I’m trying to figure out if others have run into this.
    Has anyone had sealing issues at the rack fittings using the Breeze hose kit when stacking an O-ring with a Dowty seal?
    I recently swapped my PS pump and replaced the donor lines (which were not leaking) to clean up routing. The new pump is much quieter, but now both rack fittings are consistently weeping. Not a heavy leak, but noticeable during the bleed process (haven’t driven it yet).
    Details:
    • Mustang rack with a small chamfer on both ports
    • Verified fitment with O-ring only — fitting does bottom out
    • Installed per instructions: O-ring first, then Dowty seal
    • Lubed everything during assembly
    Issue:
    • Immediate weeping from both fittings
    • Disassembled multiple times — seals look undamaged
    • Mark sent replacement seals — same result
    A mechanic I work with thinks it’ll only get worse. A local builder suggested the stacked seal approach itself may be the issue.
    Looking to see:
    • Has anyone else experienced this?
    • Did you stick with the stacked seals or change setup?
    • What actually fixed it?
    Trying to avoid chasing this further if there’s a known solution.
