12
28
Ok, piecing this together with Type 65 Coupe online manual, included RF Manual Rev Y (Jan 25 / apparently MK4), and pieces of Roadster Manual (turn signal).
1 - Aluminium pieces - it looks like the front console piece 17480 (Trans Tunnel Top Front) needs to pass 3 grommets through, and that pieces goes over 60161/60162 (Cockpit Trans Side, L/R). Go ahead and install those? I Won't install the trans tunnel until the wiring is closer to wrapped but I'll drill/cleco it.
2 - Wire groups through the Trans Tunnel . 1- Engine "power" - alt/starter solenoid 2 - sending units 3 - RF EFI bundle 4 - Rear Harness. I'm hoping I join the RF EFI bundle into the Engine Power one, as I suspect it shouldn't go with the sending units. Is 3 right? Any certain distance from the top edge of the tunnel I should aim for to be reasonably hidden?
3 - Front Harness - I think going through 60139 Footbox Inside Upper Wall, Left will be the cleanest and out of the way? I've got AN Bulkheads for hydraulics on the footbox front.
Pics below. Thanks!!!
Engine Power by Rick Shank, on Flickr
Panels? by Rick Shank, on Flickr
Fuse Box by Rick Shank, on Flickr
Front Harness Route by Rick Shank, on Flickr
