I just acquired an 818 a few days ago. Picked it up in California and trailered it back to Houston. I'm a Subaru nerd. I have 2 WRX wagons, a turbo Baja, and a high cube container full of parts from my younger days with bigger turbos and more nitrous. Back to the topic.
1) My 818 needs more ground clearance. With the coilovers adjusted to approximately midway, there's no chance of me making the transition from the driveway to the street without dragging. I can't get enough of an angle in a single car wide driveway to prevent it. If I adjust the springs to their highest setting, and hit the driveway at just the right angle, it'll clear with a fraction of an inch, BUT rides like log wagon. I have 350# front springs, 500# rear springs, riding on 18's with 30 series rubber. I have not tried running the rear at 'normal' height and just raising the front, but I suspect that it would ride alot better. The spring rate isn't THAT much different, but it was significantly more difficult to run the springs up in the rear, which leads me to believe I was preloading them more than the fronts.
Has anyone actually installed air cups from some place like stance parts? I technically would only need them on the front. Lift up the front, back down the driveway, lower it back down. That would allow me to set the ride height back to the midrange.
Has anyone toyed with softer springs in the rear and more preload? I'd have to run around higher all the time, but this is possibly cheaper and easier to implement.
I may eventually get over to MSR for a track day eventually, but to be honest, it'll probably be a few years before I do. I have 3 kids. They like to get dropped off at school and their activities in a cool car. Before the 818, it was the CJ7... which, coincidentally, rides smoother than the 818 when the springs are adjusted all the way up.
2) I may start another thread for this question, but I'll ask here anyway. Does anyone have any experience with the wilwood 6 pot front / 4 pot rear performance compared to the subaru 4 pot front 2 pot rear? Will they stop the car a bit easier, as in provide more clamping for the same amount of pedal pressure? Or are they more for racing application to reduce fade over extended use? As stated above, I have ALOT of subaru parts. I have a set of wilwood 6 pot fronts and 4 pot rears sitting in a box... complete... ready to go... just itching to be installed on something. My 818 currently has subaru 4 pot fronts / 2 pot rears, and no power booster. It does NOT stop on a dime. People are talking about adding ABS, but I couldn't push the pedal hard enough to lock up the brakes with the current setup. Maybe I'm just getting soft in my old age.
