0
0
MK4 rear of body, left to right and driver's door fitment
Hey, all. Quick question without too much back story...how often does the rear of the body need realignment left to right? I have read tons about tweaking (with a hammer, lol) the front alignment and did so a year ago. I am noticing a "little" offset between the body and the latch plates that are welded to the frame for the door latch pins on each side of the car. I see even a "smaller" amount between the tires and the fender edge on each side. I am talking 3/16" total shift toward the driver's side at the latch plates and less at the tires/fenders. Could this small amount caused issues adjusting the driver's side door to its final location? I spent a lot more time on the passenger door than most posts led me to think I would. That door is fine now, but the driver's side is giving me fits, as is normal from what I read. How much force should I need to apply to get the rear pulled out and the front pushed in to get the best fitment for the door before filling? When I pull the rear, it tries to pull the front with it. Simple push and pull with less than a lever isn't getting me anywhere close. I don't want to stress the body to the point of causing a future crack or hit a bump in the road and see the body shift to show a crappy fitment on the driver's door.
Thanks for any insights,
Mark
