Today I installed the e-brake cables. It went well with some minor modifications needed. The first was there was a clip included with each of the cables. The clip was not mentioned in the instructions, but there was a slot in the cable that seemed like it would accept the clip to secure the cable to the caliper. It did not fit so I decided to use a Dremel to shorten the legs of the clip and then it fit well.
I then moved to install the clevises. The instructions say to grind the cable ends so they fit. The cable ends are actually bigger than the picture. I had to spread the clevis a little bit to get the ends to line up with the larger part of the clevis opening. Once I did that I was able to get them in and installed. I used my handy alignment tools to spread the clevis and then pliers to close them again.
