Thanks Thanks:  7
Likes Likes:  18
Results 1 to 40 of 109
Thread: Wedel456's Build Thread - Gen3 Coupe - North Carolina
Threaded View
    Mar 2024
    Marvin, NC
    Table of Contents (part 1):
    1. Ordering & Build Specs:
      1. Preface and The Build
      2. Delivery, First Impressions, Inventory, and Car Dolly Build
      3. Tool Suggestions
    2. The Build:
      1. Suspension and Steering:
        1. Suspension Prep (Painting)
        2. Front Suspension
        3. Center Section Installation
        4. IRS Suspension Installation.
        5. Steering Shaft Installation
      2. Panels:
        1. Under Bonnet Panels
        2. More Custom Panels (interior Panels)
        3. Thought Capsule - Panel Finishing
        4. Aluminum Panels
        5. Trunk Box Fabrication
        6. Thought Capsule: Sound and Heat Deadening
        7. Panel Finishing and Off to the Upholsterer
        8. First Round of Upholstery is Back
        9. Rivet Preparation and Polishing
        10. Installing First Panels
        11. Remaining Panel Installation and Sound and Head Deadening Completed
        12. Rear Hatch Side Panel Upholstery
      3. Dash:
        1. Instrument Panel Planning and Related Items
        2. Dash Development and Customizations
        3. Dash Completed
        4. Switch Panel
        5. Finalized Dash Wiring
        6. Dash Installed
      4. Brakes:
        1. Brake and Clutch Reservoirs
        2. Pedal Box and Brake Lines
        3. Electronic Parking Brake Rear Retrofit Brake Kit
        4. Brake and Clutch Reservoirs - Mounted
        5. Final Pedal Box Installation
        6. Reservoir Connections and Brake Bleeding
      5. Engine, Transmission, Radiator, Tires, Etc:
        1. Engine and Transmission Package
        2. Radiator Tunnel
        3. Tires - The meat has been delivered
        4. Driveshaft Safety Loop
        5. Driveshaft Safety Loop - Panel Fitment Fix
        6. Fuel Lines and Gas Tank
        7. CDI Box Mounting
        8. Accelerator Pedal and Cable Installation
        9. Engine Build
        10. Engine Dyno
        11. Engine Installation
        12. Radiator Installation
        13. Finished Cooling System
        14. Power Steering Completed
        15. Transmission Mounting Fix and Shifter Location
        16. Throttle Cable Installation
        17. Wiper Motor Mounted
        18. Air Cleaner Solution
