Likes Likes:  2
Results 1 to 4 of 4
Thread: FFR MKIV Roadster, IRS, Many Options/Extras, Some Engine/Trans Parts, Mostly Unbuilt
Threaded View
    Nov 2019
    Dublin, OH
    SOLD!!
    FFR MKIV Roadster, Complete Kit (mostly unbuilt) + Options + Extras Including Engine & Trans Components - $40,000 Located in Dublin Ohio. Every single part for this car was purchased brand new (except the cap for the steering wheel). The build is largely unfinished so any changes the new owner wants can be easily accomplished for their own customization. I have over $52,000 invested and I am willing to take a nearly 25% loss. The IRS, suspension components, steering rack, fuel tank, and pedal box have been installed, and many of the body panels have been lined up and drilled, but not yet riveted to the frame. No backordered parts, everything is accounted for. If you have any additional questions, please ask. Here is what all is included:
    Factory Five Build Sheet:
    MK IV COMPLETE KIT $19,990.00
    POWDERCOATING ROADSTER CHASSIS $499.00
    351W STAINLESS HEADERS WITH KIT $699.00
    302-351 ENGINE/TRANS MOUNT KIT $0.00
    HYDRAULIC CLUTCH MASTER CYLINDER KIT $0.00
    31 SPLINE 2015 IRS 8.375" DRIVESHAFT $0.00
    BODY CUT-OUTS $149.00
    BOX 9A BLACK VINYL SEATS $0.00
    POWER STEERING COMPONENTS w/COMPLETE KIT $299.00
    FRONT LOWER ARMS - STANDARD WIDTH $0.00
    BOX 11Z - 2015 IRS PARTS w/COMPLETE KIT $2,499.00
    FFR GPS GAUGE SET W/KIT $450.00
    RDSTR FRONT SWAYBAR COMPS (4/14/15 +) $240.00
    2015 IRS SWAYBAR COMPONENTS $240.00
    CENTER DASH SUPPORT COMPONENTS $86.00
    2018 IRS 3.55 CENTER SECTION & SPINDLES $1,499.00
    WIND WINGS $99.00
    SUN VISORS $99.00
    BRAKE DUCT WIRE MESH $43.00
    1.50" ROLLBAR GROMMET SET $75.00
    ASSEMBLED SIDE LOUVER SET $85.00
    FFR ELECTRIC OIL TEMP GAUGE $145.00
    BRAKE RESERVOIR COMPONENTS $62.00
    POWER STEERING FLUID RESERVOIR $80.00
    BLANK DASH - MKIII & MKIV $0.00
    17" HALIBRAND STYLE WHEEL/TIRE PACKAGE $2,140.00
    HANDLING ON WHEEL AND TIRE PACKAGE $199.00
    ROADSTER 13" IRS BRAKE KIT $699.00
    TRUNK GAS STRUT KIT (PRIOR 05-30-2019) $99.00
    BUILD SCHOOL DISCOUNT -$250.00
    CARPET RAW MATERIAL, LINEAR YD $26.50
    14" LEATHER STEERING WHEEL UPGRADE $30.00
    Sub Total $30,281.50
    Freight (Stewart Transportation) $1,400.00
    Grand Total Paid: $31,681.50
    Additional Parts Purchased:
    Cobra F&R Badges (Finish Line) $38.00
    427 Cobra Side Badges (Finish Line) $38.00
    Cobra Steering Wheel Center Cap (Black/Chrome - Bought Lightly Used from a Forum Member) $25.00
    Waterproof Seat Heaters (Forte’s) $178.00
    Battery Box Relocation (Breeze) $169.00
    Radiator Fan Shroud (Breeze) $89.00
    Thicker .090” Firewall (FF Metal) $89.00
    Thicker Trans Tunnel Top .060” (FF Metal) $89.00
    Drop Trunk Mod (Russ Thompson) $139.00
    Turn Signal System (Russ Thompson) $321.00
    Lower Radiator Support (Breeze) $55.00
    *Driver & Passenger Side Billet Windshield Mount Mirrors (Breeze) $275.00
    Rearview Mirror w/ Windshield Center Rod & Slider Stem (Finish Line) $60.00
    427 Reverse Lockout Style Shifter (Finish Line) $99.00
    Seat Belt Bezels (Replica Parts) $60.00
    Windshield Trim Plates (Replica Parts) $42.00
    Radiator Cowl Cover (Breeze) $44.00
    Adjustable Seat Frames (Breeze) $239.00
    Gas Pedal Kit (Russ Thompson) $79.00
    Koolmat Sound/Heat Mat F&R Cockpit (Breeze) $608.00
    Door Panels (Herb’s) $205.00
    Under Dash Filler Panel (Replica Parts) $35.00
    Cockpit Storage Cubby (Breeze) $82.00
    Roadster Radiator Aluminum Panel (Replica Parts) $90.00
    Shift Knob (Breeze) $43.00
    Hydraulic Clutch Kit (Forte’s) $468.00
    Mechanical Throttle Linkage Kit (Forte’s) $194.00
    Triple Reservoir Kit (Forte’s) $367.00
    E-Stopp Electric Parking Brake Kit (520 Speedworks) $550.00
    Boltless Rollbar Kit (520 Speedworks) $80.00
    Chrome Defroster Vents (Finish Line) $36.00
    F&R Bumper Grommets (Finish Line) $34.00
    Front Air Vent Ducts (Finish Line) $40.00
    Offset Steering Rack Mounting Kit (Breeze) $60.00
    Wilwood Brake Bias Adjuster $55.00
    Steering Column Bezel for RT Turn Signal (Replica Parts) $30.00
    Brake & Clutch Pedal Pads (Russ Thompson) $22.00
    Footbox Blower Motors/Ducting/Gates (Amazon) $150.00
    LED Headlights (Amazon) $65.00
    Driveshaft Safety Loop (Summit Racing) $27.00
    Vintage Air Heater/Defroster (Summit Racing) $305.00
    Battery Disconnect Switch (Amazon) $12.00
    Power Steering Cooler (Amazon) $26.00
    Oil Cooler Kit with Thermostatic Sandwich Take-Off Plate (Breeze) $379.00
    Misc. Lights, Power Outlets, Etc. (Amazon) $100.00
    $6,000+ Paid for These Additional Parts
    Engine/Trans Parts:
    Ford Racing 427 Short Block M-6009-427F $5,294.00
    - M-6010-BOSS35195 block.
    - Forged aluminum 4.125" Mahle pistons with a 17cc dish and full floating pins & pin locks.
    - Forged H beam rods bushed for floating pins (.927 diameter).
    - Forged Steel 4.00" stroke crankshaft.
    - Clevite rod and main bearings.
    Z2 Ford Performance Aluminum SB Cylinder Heads M-6049-Z2 $2,730.00
    TREMEC TKX 5-Speed TCET17765 Ford 26-Spline .68 5th Gear TCET17765 $2,795.00
    Edelbrock Performer 351-W Intake Manifold 2181 $383.00
    Ford Racing M-9439-A50 Performance Intake Gaskets $60.00
    Ford Performance Flywheel M-6375-D302B 157T for 10.5” Clutch $300.00
    Quicktime Bellhousing RM-6065 $930.00
    Ford Racing Roller Cam Conversion Kit M-6253-A50 $73.00
    Ford Racing Roller Pilot Bearing M-7600-A $11.00
    Autolite 3924 Copper Spark Plug Set $16.00
    Ford Racing 9mm Spark Plug Wire Set – Red M-12259-R301 $58.00
    Ford Racing High Performance Hydraulic Roller Lifters M-6500-R302H $177.00
    Ford Performance Timing Chain Cover M-6059-D351 $203.00
    Ford Performance Boss Block Cylinder Head Stud Kit M-6014-BOSS $265.00
    Ford Racing 302-351W Double Roller Timing Chain Set M-6286-B302 $173.00
    Ford Performance 90* Thermostat Housing M-8592-M90 $100.00
    Ford Racing “427 Cobra” Valve Covers – Satin Black M-6582-W427B $200.00
    Ford Performance “Cobra” Oval Air Cleaner M-9600-C302 $135.00
    Comp Cams Ultra Gold Aluminum Roller Rockers 1.6 Ratio 7/16” Stud 19044-16 $413.00
    Ford Racing Head Gasket Set M-6051-R351 $95.00
    $14,500+ Paid for These engine/transmission components
  2. Thanks musman69 thanked for this post
