Hi folks, looking for the voice of experience here...
I got my front suspension more or less together and discovered some bad burrs / damage on the spindle threads when trying to put the spindle nut on. I've got a machine shop just down the road that can chase the threads and make sure its all cleaned up.
But I have spent this afternoon failing to remove the spindle from the lower control arm ball joint.
I just got back from AutoZone where I borrowed a ball joint separator - only to find it can't open wide enough to bite the ball joint stud. I've tried gentle persuasion with a rubber mallet with the blocked up to hold it in place, and some home-made threaded rod / nut gadget I threw together. This last had a chance of working I think, but the 5/16 rod I had buckled one put under compression.
Next idea is to redo the threaded rod pusher contraption, but with bigger stock.
But, at this point also looking for any other ideas. I'm used to like morse tapers in a machine tool, but never had one that is this frozen, and wonder what I'm missing here.
