I am working with a Type 65 coupe gen 3 and am looking for some help on understanding what the ride height looks like with the different mounting holes for the front LCAs (and steering rack). The upper holes are intended for track and the lowers for street application. I intend to use the lower holes but I am curious to see what it looks like as a final product and what ground clearance you end up with. Also curious to know what springs you have and how much a preload you are putting on the springs to adjust ride height.
So, I have two questions.
1. Please comment the length of your springs (front and rear) when loaded by the vehicle. Also are you using the stock 500lb/in front and 400lb/in rear springs. might be important to note what engine is in the vehicle for a weight reference.
2. What ground clearance and tire to wheel well clearance do you have - I realize tire selection will play here too. I plan to use 275/40/17(front) and 315/35/17(rear); however I haven't confirmed this yet.
