Thanks Thanks:  2
Likes Likes:  4
Results 1 to 9 of 9
Thread: Power Steering rack problem. Help?
Threaded View
    Aug 2020
    Happy Friday All,
    I need some help with a power steering rack installation problem. Like many of you I just got my power steering rack from FFR earlier this week. For reference I have a complete MK4 kit and the rack provided by FFR. I also bought the offset bushings from Breeze. SO… I was saving the install for this weekend, but I couldn’t help myself and thought I’d just sort of mock it up leaving everything loose just to get a rough idea of how it all went together. The driver’s side went fine. I had to remove some of the powder coating from the chassis holes so the bolts would go through but other than that no issues. With the DS bolt installed with no nut on it I swung the Passenger side down to install that bolt. It would go through the front chassis hole and into the bushing then dead stop. After looking at it from both sides and messing with it for a while I took the rack back out. From what I can tell it looks like my passenger side mounting holes in the chassis tabs are out of alignment by a good bit. I get it’s not going to be a perfect inline condition, but the bolt won’t even go through by itself with the rack and bushings on the bench. First time trying to include a picture so hopefully it is below. It’s a same size (1/2-13) shorter bolt for demonstration purposes with some washers pushed square against the front chassis tab. Earlier in the build I used the threaded rod on a few of the suspension tabs to “spread the tabs” as is commonly done. I didn’t really move anything doing that more than maybe .125 at the most and that mostly in the rear suspension. There was nothing unusual about the front passenger side suspension installation meaning I didn’t bend anything there. But I don’t see how any amount of bending front to back will help this. It looks to me like the front mounting hole centerline is somewhere between .3125-.3750 higher than the rear.
    That being said I’m kind of on the fence of what to do about it. I don’t want to just make the holes bigger and add slop to the whole assembly. I can’t bend anything that will help. What I’m really considering is to sort of “oval out” those two holes. Like remove .150-.175 from the bottom of the front hole and the same from the top of the rear one. Essentially making them vertical slots. That way the bolt should at least go through straight-ish. But what will that do to the Horizontal-ness of the rack itself? Is that important? Should I modify the holes based on how level the rack is? Obviously, I don’t want to tighten it down in any kind of bind. Any thoughts, experience, and tribal knowledge would be greatly appreciated before I start doing things I can’t undo.
