Hello everyone,
After checking several build threads and even specific threads about the UCAs, I still find myself not totally clear on this topic, and given that one of the potential solutions involves cutting a part, I want to make sure I got it 100% right before pulling the trigger. And as it is relevant to my question, I do have power steering for my build.
I understand that the UCAs are flipped, meaning the Right Side/Passenger Side UCA has 2 pivot bolts towards the front of the car and the Left Side/Driver Side UCA has only 1 pivot bolt towards the front of the car. However, after playing with the sleeve and jam nuts, I can't get the side with only 1 pivot bolt down to 7.375', which seems to indicate I do need to do some cutting. According to my diagram, are these the sections of the UCAs that need to be cut?
  1. What needs to be cut and by how much? The ends of the sleeves (red boxes) and/or the threads (yellow boxes)?
  2. Any best practices to do this? Type of saw, spray WD40 before cutting, etc?
Lastly, I also saw mentioned in some threads to add grease or anti-seize inside of the sleeves before putting it back together, but it's not mentioned in the manual. Is this a good idea or not?
Thank you everyone in advance!
