Guys,
When I purchased my MK I, the windshield was cracked. The crack starts at the left visor screw hole and runs to the base. Looks like someone used the wrong hardware a while back. Anyway, I wasn't able to get a replacement windshield from FFR since they were out of stock all throughout COVID pandemic so I drove it with a cracked windshield. Over a year later I finally get the replacement windshield in hand and I'm trying to install it.
I removed the entire frame from the two side rails, disassembled the frame pieces from around the glass and tried reassembling in the reverse order. Looks pretty straightforward.
Well at first I struggled to get the glass (with new rubber moulding) in the main "C" frame. The glass seemed too small, leaving a small gap on either side up in the corners. I tried lubricating the edges of the glass/moulding with a soapy water solution and that helped a little but it still won't fully seat in the main "C" shaped frame. I was starting to think the new replacement glass was slightly smaller than what was originally in the MK I. I measured it today with a cloth tape and it looks to be exactly the same size.
I'm going to try again tomorrow maybe using a different lubricant (Silicone spray, suggestions ??)
Any suggestions from any of you out there that have done this? I did spend a night searching this forum for solutions but didn't really see anything that helped.
Also, is there a list somewhere of all the hardware used in the windshield assembly, visor and side deflectors? I seem to have a lot of missing screws, set screws, etc. FFR Parts has been giving me anecdotal info as needed but it would be nice to have an entire list.
BillMac
