Likes Likes:  2
Results 1 to 5 of 5
Thread: new Tremec TKX 5-spd
Threaded View
    Folsom, CA
    more researching, soon to order my Coyote and transmission and this was the first I've seen the mention of the Tremec TKX 5-spd
    • 600 lb.-ft. of torque capacity; capable of engines speeds of 8,000 RPMs with shifts at 7,500 RPMs.
    • Available in multiple gear ratio configurations (See specifications).
    • Designed for multiple applications with three shifter locations.
    • Compact, end-loaded design provides clearance in most transmission tunnels without floor modifications.
    • Increased case strength with three-piece aluminum housing provides outstanding structural stiffness.
    • Gaskets at all flanges simplifies installation and eliminates fluid leaks.
    • Superior shift-ability through use of multi-cone synchronizers and hybrid synchronizer rings made of sintered bronze and carbon
    • All gears and shafts made from special grade steel (ASTM 4615), providing increased torque carrying capacity.
    • Equipped with a high-performance short-throw billet aluminum shifter that isolates road noise, while providing clean, crisp shifts.
    • Robust design with internal three-rail shift system and a combination of aluminum and steel shift forks.
    • Wide gear width increases gear life and torque capacity.
    • Separate GM and Ford case patterns and input configurations. Integrated GM and Ford transmission mount patterns
    Ratios here:
    https://www.holley.com/blog/post/ins...o_the_tko_t56/
    maybe it's good that I haven't ordered yet
    Todd
