Need any advice folks can offer on how to get this 427 Stroker into final tune so its easier to start. Here are the specs
Ford Z Head 427 Stroker off 351w.
QuickFuel Carb HR-680. Primary Main Jet: 70. Secondary Jet: 74. Power Valve 6.5.
AGSP32 Motorcraft plugs as recommended.
Timing set at 32 @ 4200 rpm as recommended.
Cam Lobe: 110. Duration: 242. Lift .594/.618
Using 91 Octane Fuel.
Live in San Francisco bay so I'm at sea level.
I sensed it was running rich as I could smell some gas vapors in exhaust. Pulled all the plugs and each one was black with soot. Rich condition was confirmed. Replaced with new plugs.
Installed PE Wideband lambda O2 sensor on drivers side pipe. Again, confirmed I was running richer than needed. Meter is set Set for 14.7:1. Was at ~ 0.95 at idle and in 0.80's at high rpm's.
Then I set all idle bleed screws to max vac. not all set at exact same turns. I'm at about 1 1/4 turns out but I don't know exactly.
Now O2 says I'm running at ~1.15 at idle. Running ~0.90 at highway cruise. ~3,000 rpms'.
Definitely runs better now but still hard to start. Has tons of pull but at highway cruise when I give it a hard push on the gas I get slight bumping as it accelerates. Not smooth like I would expect.
Typically, to start I push in gas pedal 2-3 times, take my foot off the accelerator and turn it over. If it doesn't catch, I repeat. I think I'm flooding at that point as I usually have to give it some pedal before the engine will catch. I checked the electric choke and set that to just closed at cold and that hasn't seemed to help with the starting. On the positive note, once its warmed up it will immediately restart with barely a turn of the key. Whether its cold outside or warm doesn't seem to have too much affect although I would say it cooperates more in warm weather.
I checked float bowls and both are right on the site lines as recommended by QuckFuel. I also have a fuel pressure meter installed right before the carb and its running at 6psi. I don't think getting gas is the problem. I'm thinking its not getting the air but I'm learning as I go.
Once started it will idle fine although it tends to want to stay at a higher idle speed to keep running somewhere around 1,100 according to my rpm meter, not the dash meter. And thats after it warms up.
It feels like I'm close but I can't get a good easy start and running perfectly smooth at fast acceleration and was hoping I could find some advice among the carb experts here. What should I do next? Is there anything else I can do or is this just the nature of the beast? All advice appreciated.
Rob
