Results 1 to 6 of 6
Thread: Front Alignment - Doesn't Look Right
Threaded View
    Aug 2020
    All,
    I've attached several pictures...
    Left and Right Hub
    Left and Right Spindle
    Left and Right Tie Rod
    I've centered the rack, but as you can see on the left tie rod one side has virtually no thread left and on the right side the hub looks toed out. I don't think there is anyway I can get the rack length out to 53 1/6 inches per the manual.
    After reviewing the pictures below what are you thoughts?
    MK4
    Spindles, Upper and Lower Control Arms -- all ordered from Factory Five
    Power Steering Rack - 1992
    Solid Bushing and Rack Extenders from Mark at Breeze (only cut rack extended amount off each end, approx. 1 inch per side)
    Left Hub.jpgRight Hub.jpgLeft Spindle.jpgRight Spindle.jpgLeft Tie Rod.jpgRight Tie Rod.jpg
    Does the setup look correct, please advise...
