0
New Engine Build - 302 | Intake Manifold Clearance Issues
Will I run into any clearance issues with the Edelbrock Performer RPM Intake Manifold (https://www.summitracing.com/parts/edl-7121/make/ford)? From what I understand a dual plane manifold is better for street applications.
Planning on running a HOLLEY SNIPER STEALTH 4150:
https://www.holley.com/products/fuel.../parts/550-870
Side note - Any recommendations on Rockers?
Based on the forum advice... I'm going with AFR 165cc SBF Renegade 20 Degree Street Heads (https://www.summitracing.com/parts/afr-1399)
302 Short Block Parts:
Pistons: Federal Mogul
Rings: Hasting
Rods: FORM OEM
Rod Bearings: Federal Mogul
Main Bearings: Federal Mogul
Cam Bearings: Melling
Ear Main Seal: Fel Pro
Gaskets: Fel Pro
Roadster Setup:
IRS
Wilwood Pedal Box
Power Steering - OEM Mustang Rack
Power Brakes w/ https://www.whitbymotorcars.com/prod...-kit-complete/
-Rear Brakes | FFR solution because I'm going with 15 inch rims
-Front Brakes | Mustang OEM
Fuel Tank | Mustang OEM
Intank Fuel Pump | TBD
15 inch Rims
T5 Transmission
302 Engine
