8
0
Lower Control Arm
Question regarding installing lower control arm Mk4.
As per manual, page 34, it says the lower control arms are using the outer set of holes on the chassis.
There are a set of holes on the inside also. What is the reason for using the outer holes?
Is it possible to use the inner holes, and if, will I run into any kind of problems?
