Results 1 to 9 of 9
Thread: Thank you BluePrint Engines!
Threaded View
    Hello folks-
    As some of you know, I recently won the engine in the contest sponsored by the folks at BluePrint Engines. I have been working with the team there to select the right engine for my project. They have been awesome to work with, and have helped me to select a great engine and transmission combination.
    The contest offered a well sorted 302 package that was terrific. However, I have been planning on a 351 based engine from the beginning of my build plan. When I shared that information with the team at BluePrint, they were happy to allow me to upgrade my engine choice to what you see here. What I ended up with was a very, very nice 408W, engine dress kit, and transmission package with the specifications outlined below. Although the engine was delivered a short time ago, I have waited until my boys were able to be with me to make my post about the engine. I really wanted them to see the engine before you all did. I hope you understand!
    I have enclosed a couple of pictures of the engine, and one picture of my boys and me with the engine. They were both home together for Christmas, which is a fairly rare event at our house. I also have posted a link to the engine dyno for those who are interested.
    I am truly overjoyed to have this engine, and am grateful to the folks at BluePrint Engines that made this happen. I can't wait until first start, first go cart, and when she is all done. I know this engine is going to make her scoot! Here are some of the details on the engine package I received:
    Engine specifications:
    Predicted HP & Torque: 425 HP / 455 FT LBS
    Actual HP & Torque: 446 HP / 496 FT LBS
    Compression Ratio: 9.7:1
    Aluminum Heads
    Hypereutectic Pistons
    Roller Cam
    Cast Steel Crank
    Block:
    Hand picked 2 bolt main seasoned 351 Windsor block bored .040 over
    Square and parallel decked
    Align honed main bearing bore
    Rotating assembly:
    New cast steel crankshaft
    New I-beam rods
    Hypereutectic pistons
    Hastings Moly rings
    Rotating assembly balanced to within 2 grams
    Melling high volume oil pump
    Hydraulic roller camshaft
    Cloyes double roller timing chain
    Camshaft degreed for maximum horsepower
    Cylinder Heads:
    BluePrint Performance Aluminum
    Hardened retainers and springs
    2.02 swirl polished intake valves
    1.60 swirl polished exhaust valves
    BP Aluminum Head Part #: HP9008
    Cam Specs:
    Roller
    .543 Intake / .554 Exhaust
    218 Intake / 226 Exhaust duration
    @ .050 - 112 degree lobe separation
    Additional bits:
    Valve covers
    Harmonic balancer
    Water pump
    Air cleaner
    Spark plugs & wires
    Timing cover
    Painted oil pan
    Brass freeze plugs
    Polished Alternator
    Power Steering
    AC compressor
    The transmission package also includes:
    Mcleod Super Street Pro single disk clutch
    Aluminum Bell Housing
    Tremec HD Yoke
    Flywheel “pro-comp”
    VSS Harness
    Reverse light harness
    Pilot bushing
    Clutch kit bolts
    Bell housing to block bolt kit
    Engine guard
    Tuff Stuff starter
    Flywheel bolts
    Here is a link to the dyno video of my engine, so you can see her performance first hand:
    https://www.youtube.com/watch?v=PCC7...ature=youtu.be
    The engine arrived coupled to the transmission with everything in place. They even ground down the parts on the Tremec transmission. It was a complete turnkey set-up, and I could not be happier! I also cannot say enough good things about BluePrint Engines!
    I thought you all might enjoy the update.
    Engine 1 of 5.jpg Engine 2 of 5.jpg engine 3 of 5.jpg engine 4 of 5.jpg Stephen, Brian, and me with engine.jpg
    Many thanks to Kevin AKA Jazzman, for his help educating me (no small task!) so that I can install pictures.
