Long time follower but this is my first post here -
I'm in the final stages of wiring my 818S and hit a snag like many. I had tail-lights, brakes, reverse, turns, and hazards working. Then when I went to start on headlights I had no power to the connector. Shortly thereafter, the taillights stopped working. Everything else is still okay.
In addition, the horns, and wiper motor don't seem to work. So steering column problem right?
Here's everything else I've traced down:
-All the fuses are good, even double checked them for continuity with a voltmeter.
- The DRL relay on the fuse block clicks when the stalk is turned to the first position (running/parking lights)
- The two headlight relays mounted together (one blue, one black) click when the stalk is further turned, but there's no power on either end of the high voltage line.
-I've played with the parking light switch, bypassing it and trying it on/off but no configuration seemed to change anything.
It seems that a few others here have had similar problems but nobody has posted a solution, either the thread goes cold or they don't follow up with a fix, so any help would be appreciated. The headlights and wipers are the last thing between me and a licence plate...
-Andrew
