I have read many posts about the drivers side uca rear pivot bushing nut hits the weld at the flange/frame. Most folks say they simply grind away a bit of weld for clearance. I hesitated to cut through the powder coat and risk weakening the joint. What I did do was to grind away one 6th of the flange on the nut so it was flush with the flat on the nut. This worked to give clearance and actually keyed the nut to lock it from turning. Hopefully this will save someone else a little grinding on a critical joint.
comments?
