Results 1 to 1 of 1
Thread: 2000 Camaro SS
Threaded View
    LCD Gauges's Avatar
    Toronto, Ontario
    2000 Camaro SS
    -114, 000 KMs
    Black exterior, black leather interior, 6 speed manual transmission
    T-Top, A/C, Tinted Windows, Keyless Entry, Factory Alarm and Anti-theft system, Power locks / windows / mirrors / steering /assisted brakes, Traction control (switchable).
    Original stereo, or aftermarket 6 channel, 400 Watt system with Alpine CD player, JVC sub 10" woofer and Eclipse speakers.
    Z06 style chrome spoke rims, wheel locks, stainless steel exhaust.
    Recent Upgrades:
    - 275 / 35/ 18 performance tires. March 2011
    - Competition Engineering 3-way adjustable rear shocks May 2011
    - Powerslot slotted rotors, Hawk HPS performance brake pads, dual piston callipers. Fall 2010
    - MSD Ignition Wires, NGK spark plugs. Fall 2010
    - Magnaflow muffler 2010
    - Waterpump, thermostat 2010
    6 Spd manual T-56 transmission with performance upgrades (Fall 2010)
    - Internal: brass blockers, sliders, complete gear set, bearings, Hardened 1-2 shift fork (photos available)
    - McLeod 800 clutch (pressure plate, disc, Aluminum flywheel), 2002 GM slave cylinder
    - Mcleod adjustable master cylinder, Pro 5.0 shifter, Lou's short stick, Hurst leather grip shift knob
    LS1 engine with several upgrades:
    AFR Mongoose performance cylinder heads, 205cc, 11.2:1 compression.
    Comp Cams roller hydraulic camshaft, custom Grind 230/234 591/598 114+4, Comp Cams Springs, hardened pushrods.
    QTP long tube stainless steel headers with high velocity merge collectors
    Magnaflow stainless steel muffler with SLP slash cut tips
    SVO 30#/hr fuel injectors, LS2 timing chain
    High flow LS6 oil pump, LS6 intake, SLP airbox with K&N high flow panel filter
    **Sale includes original stock cylinder heads, camshaft, oil pump, fuel injectors, LS1 intake and airbox
    Performance Stats:
    437 RWHP @ 5800 RPM, 414 ft./lbs. @ 3000 RPM
    12.51 seconds @ 116 MPH with 275 / 35/ 18 street tires.
    Dyno graph available
    **Latest exhaust, and PCM tuning will bring power values higher. Not yet dyno tested, but estimate of
    445 HP at the wheel and improved quarter mile of 12.3 - 12.4 on street tires @ 118 MPH.
    Other:
    HP Tuners PCM tuned. Gets 30+ MPG on the highway (measured). RPM is 1100 in 6th gear @ 110 KM/h.
    This car is surprisingly good on fuel for the amount of power available. Tuning allows for mid-grade fuel,
    or premium fuel (recommeded during warmer months).
    No winters. Rarely driven in rain (only when caught by weather change)
    Car Craft car cover
    Clean interior, and exterior
    Photos, receipts and maintenance records available
    Reason for sale: looking to build a kit car.
    Certified, e-tested
    $19,000 obo
    Write for more details, and pictures. Please pass on to your interested friends.
