I have a question about replacement of the wheel bearing seals. I took my hubs apart and had them powder coated and then replaced the bearings and seals. I should have probably taken pictures of the seals, but I thought I would be able to tell from the parts I ordered. I figured wrong.
I found out the hard way that I had the inner and outer seals swapped on my rear hubs. Basically, I destroyed an outer seal because I tried to press it in the incorrect location. I am pretty sure I have that straightened out.
Now I think I may have my front hub inner and outer seals reversed. Any chance someone can take a picture of the inner or outer seal or tell me which one has the rubber flare so I can tell if I have this backwards?
And can you tell me if I will destroy the new bearing when I take it back apart?
Thank you.
