I have a MK4 recently delivered roadster with a 3 link upgrade and an 79-93 8.8" rear end. Also has the 5 lug conversion and Cobra disc brake conversion using the factory five caliper axle mount brackets.
Right now I am fitting the rear end using the new lower control arms and brackets.
The problem I have is with wheel clearance. I have the factory five 17 x 10.5" rear wheels shod with P315/35ZR -17 Sumitomo HTR Z Tires. There is less than 1/2 inch gap between the wheel / tire and the lower control arm bracket mounted to the factory rear axle mount bracket.
Has anyone faced this problem before? First thought was to put wheel spacers on but is there enough cover over the wheel arch to keep the tires under there?
Worst case option would be to try to source different offset wheels which would not really want to do for obvious reasons.
Any help gratefully appreciated
