Thread: Factory Five MKIV Roadster Complete Kit plus more
    Dec 2012
    Richmond, VA
    SOLD
    Factory Five Mark IV Roadster for sale - Richmond, VA area
    SOLD
    I have a new addition to the family and won't be able to complete the assembly of my kit car. I hate to see it go but family has to come first. Just about everything you need including oils are in this package. I also have an engine stand, engine hoist and some Matco tools for sale separately to help put everything together. A combo deal could be worked out to include the kit car package, tools and engine stand and hoist. (See below)
    Here is what is included in this Cobra package: $29,000 negotiable
    Factory Five Mark IV roadster Complete kit (retails for $19,990 by itself)
    - too much to list individually, go to https://www.factoryfive.com/kits/mk4.../what-you-get/ to see everything that comes in the Complete kit
    - Ford Racing 5.0 L Coyote Engine w/ flywheel (rated at 412hp / 390 ft-lb torque) Emissions legal
    - Ford Racing Engine install kit (ECU, wiring harness)
    - Ford Racing Tremec 6-Speed Transmission
    - Hudlow Axle Custom Rear end Assembly (posi, Ford 8.8, 3.73 gears, 31 spline axles)
    - Brembo Front Brake Kit (rotors, brackets, lines)
    - Ford Racing rear brake kit
    - Auto Xtra Ceramic disk brakes
    - A1 Cardone Friction choice calipers (left & right) (18-B4824) (18-B4825) $61.95 each
    - Royal Purple engine oil, transmission oil, gear oil
    - Weld Wheels Forged Five Spoke Front 17 x 11, Rear 17 x 12
    - Mickey Thompson Street Comp Tires - Front 245/45R17
    - Mickey Thompson ET Street Radial II - Rear 315/35R17
    8_Matco_JSC500_ServiceCart.jpg1_BodyFrame_Front.jpg2_BodyFrame_Rear.jpg3_PartsBoxes.jpg4_FordRacing_Engine.jpg5_Tremec_Transmission.jpg6_HudlowAxle_RearEndAssembly.jpg7_WeldForgedWheels_MickeyThompsonTires.jpg
    The following items are being sold separately from the kit car package. If you wanted to buy everything together then I could do a combo deal of $33,000
    Engine stand and Engine hoist from Summit Racing - sell for $250 for both
    Tools for Sale: $4150 for all shown below
    Matco Tool Box - Jamestown Service Cart JSC500
    Matco Tools
    - 12 pc Opti-Torque Pro Long Combination wrench set (SMCL122T)
    - 10 pc Opti-Torque Pro Extra Long Combination Metric wrench set (SMCXLM10T)
    - 3 pc Multi-Position Prybar set (IDPOSET3)
    - 8 pc Screwdrivers set (SSO8C)
    - 18 volt ½" Drill Driver Kit (MCL18DDKIT)
    - ½" Impact Wrench (MT1769A)
    - 3 pc Extra Long Needle Nose Pliers set (PNO3SB)
    - 3 pc High Leverage cutting pliers set (SPDC3)
    - 3 pc Alligator Pliers set (PA3S)
    - 3 pc Wire striper / crimper (MST700E)
    - Torque Wrench TRC150 (CG3150FTC-MTB)
    - Klik Fast rivet tool HP-2 riveter (61660) not full kit (kit price $93.85)
    - 3 pc ratchet set 1/4th, 3/8th, 1/2th (SRTD3T)
    - 1/4th SAE socket set 9/16th -- 3/15th (SA106TB) qty 2
    - 1/4th Metric socket set 6 -14 mm (SAM92TB)
    - 3/8th SAE socket set 1" -- 1/4th " (SB136TA)
    - 3/8th Metric socket set 19mm -- 8mm (SBM122TA)
    - 3/8th Metric socket set 22mm -- 6mm (SBM176TA)
    - 1" SAE socket set 1" -- 7/16th" (SC106TA)
    - 1" Metric socket set 24mm -- 10mm (SCM156TA)
    Roanoke Rapids NC
    I am interested in your car. How can I contact you?
    Dec 2012
    Richmond, VA
    Quote Originally Posted by rrtang View Post
    You can always send me a private message. Click my user name and select Private Message from the menu.
    Dec 2012
    Richmond, VA
    Car Package and Tools now Sold.
    Thank you.
    Stoneville NC
    Somebody got a heck of a deal.
    Al Adkins
    Certified "Kool Aid" drinker
    Owensboro, KY
    Quote Originally Posted by Raceral View Post
    Yea! Helluva deal!
