Results 1 to 4 of 4
Thread: 33 Hot Rod Brake Question
    Why are there two different size brake fluid reservoirs for the 33 Hot Rod. Both are firewall mounted & polished one has a tank depth of 2 inches and the other has a tank depth of three inches. The smaller one has a knurled screw on cap and the other has more of a toothed design to the screw on cap. I have the Wildwood disc brakes on the front that were included with the kit and stock Ford disc brakes on the 1996 Ford Cobra 8.8 rear end on the rear. Which of the brake fluid reservoirs is recommended?
    Vinny
    You got an old on and a new one. Maybe if you call them they will make it right
    Thanks for your reply. Unfortunately, I started by calling them to ask this question. I got a recording telling me to leave my name and number and never got a response which is why I decided to try this forum. Maybe I wasn't clear I have two of each and don't know if one is a newer version. It sounds like you're saying the three inch deep reservoir is the newer version. Is that correct?
    the one with the non knurled cap is the newer ones. large aluminum
  5. Thanks Vinny33 thanked for this post
