Results 1 to 3 of 3
Thread: MK4 Roaster - Rear Sway Bar
    Nov 2023
    Ottawa, Canada
    Hello,
    Dose anyone know what hole (there are 4) I should use on the sway bar the manual shows a different one!
    Also if anyone know the difference between the holes i.e. softer at the end or max stiffness in case i need to adjust it later !
    The holes closer to the pivot point (inner) are stiffest and the ones farther from the pivot (outer are softest).
  3. Thanks Puckboy thanked for this post
    Likes Puckboy liked this post
    Nov 2023
    Ottawa, Canada
    Thanks Jeff, I ended up opting for the second hole so in the middle I guess
