Results 1 to 3 of 3
Thread: 2015+ IRS Flex Line lengths and/or part number
    Aug 2023
    San Diego, CA
    Hi All,
    Okay, I give up. After weeks of looking thru this forum, buying stuff, returning it, buying more stuff... I'm stuck. I'm sure this info is on this forum somewhere but I can't find it.
    Running a 2015+ Mustang IRS with the stock Mustang brakes for my Mk4. What are the part numbers for the flex line from the caliper to the mounting bracket. Or else, what are the suggested lengths or minimum lengths others have used successfully?
    Seen these 2 mounting locations and they are where I'm targeting: Brakes, rear, mounts.jpgSuggested BL Mount, Dr, Rear.jpg
    Thanks for your help,
    --Jay
    ______________________
    Current project: Mk4 build started September 2025
    O'Fallon, MO
    How about taking a tape measure and see what it takes.
  3. Likes Mike.Bray liked this post
    Aug 2023
    San Diego, CA
    Haha. That would be too easy. I found the tape measure method doesn't account for:
    1. the extra length needed to account for wheels travelling up and down
    2. just adding a few extra inches gets in the way of the shock/spring
    3. The length of rigid connection and routing from the banjo bolt/caliper connection.
    I was hoping someone would say... here's a p/n I've used and it worked ok, good luck.
    Jay
