Hello all...I hope people aren't going to get annoyed of my questions while I'm learning/figuring this car out. I've been trying to get it prepped so that I can get it retuned but as I fix one problem, I find other problems.
With Holley's technical help yesterday, I was finally able to sync my laptop and Holley ecu (we had to try a lot of different/older versions of their software). This unfortunately led to finding that the ecu wasn't reading the fuel pressure (mechanical gauge in the engine bay was properly set and working, ecu was saying "low Err") along with the oil pressure wasn't reading properly in the ecu. It was showing up as 7-9psi while my mechanical cockpit gauge was reading 60psi on cold start idle. The Holley tech said that these two issues could be related regarding wiring.
So I'm in need of a little guidance on finding/identifying these two sensors. I don't even know if they are necessarily bad either as it could be wiring since I'm finding wiring issues. Once I knock these out, I can finally get the car properly tuned.
I'm wondering if this is the fuel pressure sensor? It is on the passenger side near the firewall and has a line running from it to the top of the block sitting between the ITB's. There is no labeling on it, so I could be completely wrong.
Screenshot 2025-10-21 at 3.09.57 PM.jpgScreenshot 2025-10-21 at 3.10.07 PM.jpg
For the oil pressure sensor, what I'm a little concerned on is that the cockpit gauge seems to read it fine, but the engine ecu isn't...not sure what could be causing that.
Also, while I identified the green ground wire that was loose (when touching it against the engine block the "cooling fan relay" under the dash was clicking), I'm having a hard time figuring out what this black wire with a grey line is. Trying to trace it back and it appears to run into a line that goes into the rear firewall directly behind the engine. That could be the oil pressure issue for the ecu by reading the below diagram if that wire is considered "grey"...and if so where do I properly hook this wire up to?
Screenshot 2025-10-21 at 3.10.32 PM.jpgScreenshot 2025-10-21 at 3.35.57 PM.png
I keep finding more and more exposed wires not connected to anything which is frustrating. I know there are probably plenty of wires not used, but I would expect those to be taped up, not where the rubber shielding is stripped and wire is exposed.
After I figure out the oil pressure and fuel pressure sensors for the ECU, I can then hopefully tackle down why the headlamps aren't working and then the left turn signal (all turn signals work when the emergency lights are turned on however).
I'm very grateful for all the help I've already had, and continue to get.
