Results 1 to 6 of 6
Thread: IRS Differential oil quantity.
    Jun 2023
    Curious if the IRS limited slip diff that comes with the kit has shipping oil in it. I filled mine without checking and it took less than one quart and it’s supposed to take 1.2 Quarts + 3 oz of friction modifier.
    Apr 2021
    Fort Mill, SC
    Just went through the same thing with my IRS. Took about 3/4 qt.
    Rob
    Mk4 Complete Kit, #10465
    Ordered 11/14/21, Build School 5/20/22, Delivered 8/22/22, Engine/Transmission Delivered 3/27/23, Installed 9/3/23, First Start 2/14/24
    347FI/TKX/IRS "Street Look"-no hoodscoop or rollbar, undercar exhaust
  3. Thanks Green Roadster Build. thanked for this post
    Aug 2022
    Portland, Oregon
    I ended up with a drain pan full, it did not take the recommended amount.
    May 2013
    OH,KY,WV tri-state area
    If you are running a true trac,....... to me they look like they have Much more mass than a OEM carrier or a OEM lS carrier. If they really do have a more metal they will take up some of the lube Capacity.
    Folsom, CA
    I got my diff from Forte, he had to drain prior to shipping - surprised they ship with fluid to be honest... but sounds like it's happening
    I believe I did about 1.75 qts of Valvoline SynPower SAE 75W-90 Full Synthetic Gear Oil which has friction modifier already included
    Todd
    Oct 2019
    Erin, Ontario CANADA
    Perhaps this chart is of use:
    axlelubeUS (1).pdf
