Thanks Thanks:  2
Results 1 to 8 of 8
Thread: Koni Shocks not right??
    May 2023
    Central Iowa
    So I was putting my shocks together and read in the manual that the rear shocks are 2.5" longer than the fronts. Measured them and that is the case with mine. front shocks are koni #822610 and the rear # is 822611. The threaded adjustment sleaves and all the other parts, except for the springs (one is 400# and the rear are 250#) are the same. My rear shocks, with the adjuster all the way up, has about a 2" gap between the top of the coil spring and the retaining hat when fully extended. Is this right? That means if I put my truck on the lift that my springs will be loose around the shock. Another person on the forum said that the truck coil overs are supposed to be the same length as the fronts. Did I get the wrong coil overs or just the wrong threaded adjusters?
    May 2023
    Central Iowa
    Well I can’t help about the parts you have, but yes when the suspension is unloaded it’s normal to have a loose spring. Most tie wrap the spring to the top hat to keep it in place.
  4. Thanks KippRacing thanked for this post
    Placitas, NM
  6. Thanks KippRacing thanked for this post
  7. #5
    May 2023
    Central Iowa
    Thanks for the help guys. I guess the thread I was reading that said the shocks should be the same length might have been for the older truck design.
  8. #6
    Sep 2015
    Hamersville, Ohio
    I’d either get longer springs or add a short soft spring on top to make the ride more comfortable. Jmo.
    Kit #361, arrived 10/2015, still in progress
    818C highly modified, corvette suspension
    Estimated completion summer 2023!
    1989 turbo Supra 5 sp
    2017 Tundra
  9. #7
    Placitas, NM
    You can’t add a second spring, both will flop around where the 2 meet.
    Here’s a better pic of what I was explaining in post 4 above.
  10. #8
    May 2023
    Central Iowa
    My shocks don't have a 2nd snap ring groove. Factory 5 said that this is the way the new shocks are.
