Results 1 to 3 of 3
Thread: RT Turn Signal - Too Tight?
    Dec 2018
    Sherwood Park, AB
    Question RT Turn Signal - Too Tight?
    Hi,
    I have about 100 km on my first MKIV build. I have the RT Turn Signal system. I've noticed that it seems a little tight, so much that if I turn left in my driveway, the left signal comes on all by itself (i.e. the stalk engages). And when I signal to turn right, it's a bit stiff and won't always stay engaged. Sometimes I have to hold it there. And then, as I finish the right turn and bring the wheel back counter-clockwise, the left signal will engage on it's own and so I have to pop it back up.
    Just wondering if this is just normal break-in stuff and whether or not it might loosen over time. Or, if I need to adjust something or spray some lubricant in the mechanism.
    32J
    Nov 2016
    "The i.e." SoCal
    You have the steering wheel hub to close to the turn signal switch. Try to maintain an 1/8" gap between the back of the hub and the face of the turn signal mechanism.
  3. Thanks 32J thanked for this post
    Dec 2018
    Sherwood Park, AB
    I did notice it looked a little close. Thanks!
