Thanks Thanks:  21
Likes Likes:  18
Page 3 of 3 FirstFirst 123
Results 81 to 102 of 102
Thread: FLFrank's '35 Hot Rod Truck Build
    Aug 2019
    Fort Lauderdale
    Looking good
  2. Thanks FLFrank35 thanked for this post
  3. #82
    May 2019
    Viera, FL
    Smile I think it's finished
    IMG_5759.jpg IMG_5762.jpg IMG_5763.jpg IMG_5764.jpg IMG_5766.jpg IMG_5767.jpg IMG_5769.jpg IMG_5693.jpg IMG_5771.jpg
    The doors still droop a little and the bottom rear corners aren't flush. A little water got in when I gave it it's first bath. I guess I'll have to upgrade the door seals.
    Otherwise, I think it's ready for the road...just waiting for my title/tags.
    Thanks to everyone who provided input and answers!! I really appreciate it
  4. Likes Chopper, RuffShod, FF33rod, Salty Chief 35 liked this post
  5. #83
    Northern Virginia
    Lookin' good! I really like your quilted trans cover/headliner.
    And it's done, but you'd be bored if there wasn't something to work on!
    FFR MKIV 8309, FMS 306 Crate w/Edelbrock EFI, T5, 3.55 Three Link, Wilwood Brakes
  6. Thanks FLFrank35 thanked for this post
  7. #84
    Jan 2019
    It looks excellent. I really like the interior. Should be winning best in local shows before summers end!
  8. Thanks FLFrank35 thanked for this post
  9. #85
    Aug 2018
    Hampshire, IL
    Congrats on your build. It looks great. Thanks for the pics you gave me some ideas on how to upgrade my interior this winter. Rob.
    FFR 35 p/u # 0016 Dart 347 TKO 600
  10. Thanks FLFrank35 thanked for this post
  11. #86
    Aug 2019
    Alvin, Texas
    Well done!!!
    Excellent craftsmanship!!!
  12. Thanks FLFrank35 thanked for this post
  13. #87
    Bourne-Cape Cod, MA
    Looks fantastic, those doors are tough....
    FFinisher/AKA RE63
  14. Thanks FLFrank35 thanked for this post
  15. #88
    Apr 2019
    Outstanding!
    Jeremie
  16. Thanks FLFrank35 thanked for this post
  17. #89
    I like it a lot. Looking forward to mine getting that far along. I like your interior roof treatment. I may copy something like that for mine.
  18. Thanks FLFrank35 thanked for this post
  19. #90
    Aug 2019
    Alvin, Texas
    Interior looks allsome!!! I'd like to see a video or detailed explanation of what you used to do it, how it was attached, etc. I've never been exposed to that type of craftsmanship.
  20. #91
    May 2019
    Viera, FL
    Quote Originally Posted by RuffShod View Post
    LOL..."craftsmanship" . I'm probably more of a hack, but thanks for the comment. I've only done a sailboat headliner prior to this and this was different...there were channels on the ceiling of the boat to tuck the headliner into and no rollbar. With the truck, I kind of improvised. I am not a carpet/headliner installer and I am not good with cutting material around curves/corners. I had to figure it out as I went along.
    To start off, my body guy noticed that the roof was sagging (I didn't see it) so he added some wood bracing.
    I think he epoxied it or used resin. That gave me something to screw into, which worked out well because I had planned to add some fir strips anyway.
    Next, I put some Dynaliner on the ceiling and sidewalls.
    I cut out around the wood strips. Ideally, I think you'd want the wood fir strips and the insulation the same thickness so it's relatively level. My wood strips are about 1/2" thick and the Dynaliner I used is 1/2" thick.
    Then, I took some measurements, cut the cardboard and screwed it to the wood strips.
    I cut 2 pieces so it would be easier to slide into place above the rollbar. Had to go in and out several times to cut it just right. I used a sharp utility knife and #8-9/16" truss screws to screw into the wood. Very important...do not screw through the roof...obviously. Note: You have to leave a small gap at the edges/corners so you can tuck the material into it to hide the edges...in other words, cut the cardboard smaller than the surface area of the ceiling, don't go all the way to the sides/corners with the cardboard. Ideally you should have a gap (1/4" - 1/2") between the cardboard and the ceiling and enough room so you can tuck the material around the edges.
    Next, I applied some heavy-duty Velcro about every few inches and here is where I erred...
    The adhesive-side of the Velcro sticks fine to the Dynaliner, fiberglass, and cardboard, but it does not adhere the the vinyl headliner foam-backing. I removed the Velcro from the ceiling and used Shurtape double-sided carpet tape. That also sticks very well to everything but, like the Velcro, doesn't adhere to the vinyl headliner foam-backing. My goal here was to make it removable (in case I wanted to add/change something later) but the next attempt will be to use 3M spray adhesive which will make it pretty permanent.
    I cut the material larger than needed then trimmed it once it was in place with a good pair of scissors. You'll want 1 to 2" (or as needed) extra headliner material around the edges of the cardboard. I used a putty knife to tuck the excess material up above the cardboard into the gap. If it has trouble staying in place, use some of the double-side carpet tape.
    For the sidewalls I used trunk liner material (carpet would probably work just as well). It was inexpensive and easy to work with. I sticks well to the hook-side of the Velcro. Disclaimer: I have several pieces around my corners and around the doors because I haven't learned to cut material around curves. A lot of trial/error, but the edges of the material blend together well and stick to the hook-side of the Velcro and the double-sided carpet tape. Did I mention I'm not a carpet installer?
    I hope I explained it well enough. Let me know if more explanation is needed.
    Here are the links to the materials. Most are inexpensive and easy to work with, except the cardboard is a little difficult to cut.
    Good luck!
    https://smile.amazon.com/Dynamat-111...e%2C170&sr=1-1
    https://www.automotiveinteriors.com/waterproof-cardboard-door-panel-board-cowlboard-p/cowl-dp.htm
    https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
    https://smile.amazon.com/dp/B08GFB8C...roduct_details
    https://www.lowes.com/pd/Shurtape-1-...m-Tape/3407976
    https://www.fabricempire.com/vinyl-soft-grain-texture-high-quality-red-thread-quilted-black-fabric-2-x-3-diamond-with-3-8-foam-backing-upholstery-52-wide-sold-by-the-yard.aspx
    IMG_3074.jpg IMG_4945.jpg IMG_5046.jpg IMG_5047.jpg IMG_5048.jpg IMG_5056.jpg IMG_5058.jpg IMG_5473.jpg IMG_5494.jpg
  21. Thanks Salty Chief 35 thanked for this post
    Likes RuffShod, Chopper liked this post
  22. #92
    Aug 2019
    Alvin, Texas
    Allsome explanation!!!
    Thanks!!!
  23. #93
    May 2019
    Viera, FL
    Thanks!!!
    You're welcome, hope it helps!
  24. #94
    Sep 2019
    Houston, TX
    Very nicely done!
  25. #95
    May 2019
    Viera, FL
    Aug 2022
    The Villages, Fl.
    Salty Chief, did you get your kit yet? Mines on order and I'm in the process of collecting parts for the build. I'm in The Villages.
  27. #97
    Apr 2019
    Not yet. I’ve been gathering parts but have 1 of my kids left in college. I have a 351 Cleveland I’ve been working on and getting ready. Also have a few aesthetic things that I plan on using that I’ve collected. Hopefully towards the end of next fall.
    What kit did you end up ordering? What’s your build details?
    Respectfully
    Jeremie
  28. #98
    Jun 2022
    Looks awesome. Your thread has been helpful as i've started my build.
    What kind of Trans cooler did you get? Where did you mount it?
  29. #99
    May 2019
    Viera, FL
    Quote Originally Posted by johnnyfive View Post
    Thanks! Glad I could help someone. I Received a lot of help on this forum, as this is my first build.
    I mounted it under the rear, left side of the bed, above the fuel tank. If you didn't see it, here are a couple pictures from my thread...
    Wallace18 put one in his truck and has some good pics at his thread, post #105 https://thefactoryfiveforum.com/showthread.php?26958-Wallace18-s-35-Hot-Rod-Pickup/page3
    He recommended it to me, so I got the same one...
    Part # 57313211 Perma-Cool 13211 Maxi-Cool Jr. 6-Pass Transmission Cooler w/8 Inch Fan https://www.speedwaymotors.com/Perma...Fan,97986.html
    Part # 91064044 Speedway Budget 40-Amp Electric Relay Kit https://www.speedwaymotors.com/Speed...-Kit,7052.html
    Part # 57318899 Perma-Cool 18899 Inline 185 Degree Thermoswitch, -6 AN https://www.speedwaymotors.com/Perma...-AN,97988.html
    Good luck!
  30. Thanks Just 1 More thanked for this post
  31. #100
    Aug 2022
    The Villages, Fl.
    Jeremie, lost your post. Extended cab ordered, due April 8,23. ZZ4, holly sniper, 4L60E, 8.8 mustang 3.55 posi, power brakes, A/C. Still trying to decide on fenders, full vs motorcycle, too much rain here in Fl. to go bare. DonS
  32. #101
    Apr 2019
    Sent pm
    Respectfully
    Jeremie
  33. #102
    Mar 2023
    Quote Originally Posted by FLFrank35 View Post
    Thanks for the suggestion. I'll study it and see how that might work.
    Good luck unpacking.
    I drilled and tapped a1/4" hole in the frame mounting ear to match the 1/4" hole in the radiator bracket. Can't move anymore!
