Results 1 to 3 of 3
Thread: Dumb question - which oil sensor is which?
    Aug 2019
    Gen 3 coupe build with gen 3 coyote. Finally on wiring, but can't tell or forgot - which sensor is the oil pressure and which sensor is the oil temperature:
    Big round lower one is which?
    Smaller higher one is which?
    Any ideas for a cover on these? It seems odd to just screw on the wire and leave it exposed....
    Aug 2019
    Verona ILL
    Big is oil pressure. Small is water temp No cover needed you won't see them. If it truely is a Gen 3 Coyote you need the stock oil pressure sensor in it as well, ECM will look for it.
    Mk4 9735 complete kit delivered 11/29/19 Gen 3 Coyote, Tremec TKO 600, Moser 3.55 First start June 25, 2020 First Go Cart July 20, 2020
    Aug 2019
    yryasko,
    Got it - thank you!
