Results 1 to 4 of 4
Thread: Fuel Tank Cam Lock Ring - How Far to Turn for Tab Lock?
    Dec 2018
    Sherwood Park, AB
    Question Fuel Tank Cam Lock Ring - How Far to Turn for Tab Lock?
    Hi Folks - I just installed a Holley Sniper 340LPH in-tank fuel pump. I turned the cam lock ring, but I'm not certain if I have to keep going until the top of the chrome tab is directly centered below the indent in the corresponding grey tab "ear". Should I keep turning it?
    32J
    Port Charlotte, FL
    32J,
    No, that's perfect where it is now. Make sure you put the rubber o-ring, gasket under the pump.
    Henry
    Dec 2018
    Sherwood Park, AB
    Too late... Decided to knock it a bit further. The peak of the cam tab is now centered under the tab ear. It's not any higher than it was when it was just outside the tab. And yes, the rubber o-ring is in there.
    Jul 2021
    Big Canoe, GA
    I went 'all the way' also, just yesterday, locking the cam tab under the detent. very solid fit.
    I have to say I'm impressed with PRO-M's pump hanger and TechAFX's 5 micron filter and BlackWrap fuel lines.
    F2CCA043-1DAF-439E-A61A-E2B405AA0CD1_1_201_a.jpg53B47BB4-B20C-46E5-9678-D8F5C629CC9A.jpg
