Results 1 to 3 of 3
Thread: 10 Pin instrument wiring question
    May 2016
    Background info.
    I bought an unfinished Gen 2 GTM.
    I am reviewing what was done and doing what needs done.
    My current rabbit hole is the dash/interment wiring.
    Specifically, the 10 pin connector.
    Can you either point me to where I can find the GM wiring diagram pin out for this
    Or
    If you say the wire that goes/is to
    pin 1 white – instrument lighting
    pin 2 black - left Turn Sig
    Pin 3 purple – tach ??
    Pin 4 drk blue – right Turn Sig
    Pin 5 lite blue – left Turn Sig
    Pin 6 black seems to be ground that terminates the led a pings 2, 3, 4, 10 7
    Pin 7 orange 500 ohm resister tach
    Pin 8 ??
    Pin 9 is open
    Pin 10 is blights.
    Can you either confirm and/or let me know what it should be?
    Indiana
    GTM #304 LPE 525hp LS3
  3. Thanks WIS89 thanked for this post
    Likes WIS89 liked this post
    May 2016
    Fabolous!
    That should save multiple questions in the future.
