Likes Likes:  6
Thread: seat warmers installation
    Folsom, CA
    Question seat warmers installation
    I got the Cobra Valley Seat Heaters - REALLY well built product!
    Their directions are for the older style seats with hog-rings, the newer designed seats are a bit different
    I got the back portion installed pretty easily, just undo the bottom tensioning brace and you can get your arm inside pretty easily - applied the tape, and done
    the seat portion isn't' as forgiving, and before I unglue a side to lay in the heater - is there some magic I'm missing? or do I 'unglue' and re-glue after installing?
    Thanks!
    Todd
    On a roll
    Wheaton, IL
    Toadster - check out this thread from a few years ago. I had similar questions, and the collective wisdom helped me out. I'm pretty certain I didn't have to glue anything. Here's the link: https://thefactoryfiveforum.com/show...-cover-removal
  3. Likes toadster liked this post
    Folsom, CA
    Thx Al_C - I misstated, the seatback is easy, it's the bottom seat cushion part I'm struggling with... it's all glued, no hogrings or holding strips
    Todd
    Yup. Bottom cushion requires the fabric to be pulled off the foam and then re-glued when you're done. Every one I've ever done was about to fall off anyway. Not sure what glue they use but isn't great. I used DAP gel contact cement to re-glue. Available at Lowes, HD, etc.
  6. Thanks WIS89 thanked for this post
    Likes toadster, bobm488, Geoff H liked this post
  7. #5
    Jul 2014
    Buffalo NY
    Does anyone know if these seat heaters are the best ones for the FFR diamond stitch seats? I tried purchasing the Cobra Heat ones and I think they are out of business.. No joy on submitting an order on their website and email gets kicked back immediately.
    Thank you!
    10/29/25 MK4 Delivery Day
  8. #6
    Dec 2021
    Flagstaff, AZ
    I bought mine from Mike Forte. Good quality parts.
    289 Roadster Delivered 02/25/2023
    Blueprint Engines 302, IRS, TKX
    First Start June 2024
    Street legal July 2025
  9. Likes LSX liked this post
  10. #7
    I also found the Cobra Heat website wouldn't accept an order along with several reports they weren't available from them any more. Messaged Mike Forte and he said he would get back to me. He didn't. I ended up using Corbeau seat heaters from Summit in my Mk5 build with the diamond stitched seats. Installed fine. Details in my build thread thread here: https://thefactoryfiveforum.com/show...l=1#post597880
  11. Likes LSX liked this post
