Results 1 to 1 of 1
Thread: Whibty | Pushrod | Master Cylinder | Videos
    Aug 2020
    All,
    Whibty sent a new master cylinder... Installed same exact problem...foot goes all the way to the floor.
    I took two videos prior to installing the new master cylinder.
    1) Should the Pushrod be able to be pull out like the video shows?
    2) Should the hole be closed in the rear master cylinder prior to engaging the pushrod? You can see the hole is not closed, but on the front cylinder, the hole is closed until the pushrod engages the cylinder
    https://www.mattmaresch.com/Private-...aster-Cylinder
