Likes Likes:  2
Results 1 to 5 of 5
Thread: new Tremec TKX 5-spd
    Folsom, CA
    more researching, soon to order my Coyote and transmission and this was the first I've seen the mention of the Tremec TKX 5-spd
    • 600 lb.-ft. of torque capacity; capable of engines speeds of 8,000 RPMs with shifts at 7,500 RPMs.
    • Available in multiple gear ratio configurations (See specifications).
    • Designed for multiple applications with three shifter locations.
    • Compact, end-loaded design provides clearance in most transmission tunnels without floor modifications.
    • Increased case strength with three-piece aluminum housing provides outstanding structural stiffness.
    • Gaskets at all flanges simplifies installation and eliminates fluid leaks.
    • Superior shift-ability through use of multi-cone synchronizers and hybrid synchronizer rings made of sintered bronze and carbon
    • All gears and shafts made from special grade steel (ASTM 4615), providing increased torque carrying capacity.
    • Equipped with a high-performance short-throw billet aluminum shifter that isolates road noise, while providing clean, crisp shifts.
    • Robust design with internal three-rail shift system and a combination of aluminum and steel shift forks.
    • Wide gear width increases gear life and torque capacity.
    • Separate GM and Ford case patterns and input configurations. Integrated GM and Ford transmission mount patterns
    Ratios here:
    https://www.holley.com/blog/post/ins...o_the_tko_t56/
    maybe it's good that I haven't ordered yet
    Todd
    Master Builder
    Long Island, NY
    They are in short supply right now.
  3. Likes toadster liked this post
    Folsom, CA
    Quote Originally Posted by first time builder View Post
    yeah I bet!!!
    Todd
    Jan 2021
    Memphis, TN
    I'm waiting on my 347 from Blueprint with the TKX, ordered in January and they are telling me to check in April.
    Jul 2020
    Newport Beach, California
    Yea I've been waiting for my TKX for four months. Good news is Forte just got 6 and I'm on the list to get one.
    Matt
    FFR Complete Kit, Coyote, Tremec TKX, 3.73 IRS, power steering, 18" Halibrands, Wilwood brakes, Gas-N pipes + header, Viking blue color
    Roadster Build Time Tracker
  7. Thanks toadster thanked for this post
