Results 1 to 4 of 4
Thread: Scorpion Roller Rockers 1.6 | 302 | Value Covers Fit?
    Aug 2020
    All,
    Stock 302, AFR 165 Heads
    What valve covers fit over Scorpion Roller 1.6 Rockers?
    Rocker Arms, Stud Mount, Full Roller, Aluminum, 1.6 Ratio, 7/16 in. Stud, Ford, Small Block
    Prefer the Power by Ford look
    Matt
    Southport, NC
    Start with a search like: tall ford racing valve covers for 302
    This is the page I came up with: https://www.google.com/search?rlz=1C...4dUDCA0&uact=5
    Realize that your type of intake will matter too. Some tall valve covers will interfere with the stock Ford EFI intake. If you have a carb or carb like EFI it should not matter how tall they are.
    George
    mburger's Avatar
    Punta Gorda FL
    Just one source of 100s like George posted.
    http://store.cobranda.com/28vaco.html
    Mark
    Gone but not forgotten. Mk1, Frame #1929 Complete restoration/upgrade.
    Maumee, OH
    I used the standard cobra valve covers with the comp roller rockers. I also installed a 1/2" spacer under the valve cover. Just make sure you tighten them down and recheck them after a few heat cycles. I had no issues.
    Scott
    Built FFR9457. 351 Windsor, TKO600, 3.73. Fitech EFI. Russ Thompson throttle pedal, turn signal, and trunk pan. Carbon Fiber dash with Speedhut Revolution gauges. Paint by Jeff Kleiner.
