I've been researching the heck out of these parts, and need a check...
Here's the Fuel System recommendations in the Gen 3 Coyote Install Instructions (Download)
Summit Racing - Fuel System
AEI-13129 6AN Fuel pressure regulator
SUM-220166B 6AN O-ring to straight 6AN Adapter (2 needed)
SUM-220701-B 6AN to -6AN Hose Barb (1 needed)
FRA-495110-BL 6AN O-ring to straight -4AN Adapter (1 needed)
SUM-220700-B 4AN Hose Barb (1 needed)
SUM-220711-B 90ฐ -6AN to -6AN Hose Barb (1 needed)
SUM-800199 0-100 EFI fuel pressure gauge
GSL392BX Fuel Pump or VOR-8F002-265 Fuel pump
VPN-400-939 Fuel pump mount/barbs for GSL392BX pump
My setup for Boyd Tank to Gen3 Coyote Fuel System
EAR-AT949006ERL -6 AN Male to Male 9/16-18 adapter (1 needed at pump outlet)
AEI-13136 6AN Fuel pressure regulator (1 mounted on firewall)
SUM-220166B 6AN O-ring to straight 6AN Adapter (3 needed on FPR)
SUM-250690B - PTFE, Straight, Reusable Swivel, -6 AN Female Thread, -6 AN Hose (6 needed)
AEI-15633 0-100 EFI fuel pressure gauge (connected to FPR)
RUS-660843 - Russell ProClassic AN to NPT Adapter (AN to NPT return)
AEI-11542 Aeromotive Stealth 340 In-Tank; 340lph @ 90psi (in tank)
SUM-220985 - Summit Racingฎ -6 AN PTFE Hose Braided Stainless Steel, -6 AN, 20 ft. (1 needed)
Not sure if hose-barbs will be needed since I'm doing AN lines? (from the install guide)
also, what's the connector into the actual Coyote Fuel Rail? shows a clip... with clamp?
what line should be used here?
Fuel lines
- Push the white fuel line connector onto the fuel rail.
- Hold the fuel line up to the connector and cut it to length with a razor knife.
- Remove the fuel line connector.
- Slide a hose clamp onto the hose then push the fuel line connector into the hose and tighten the clamp.
