Hello,
I have a Wilwood upgraded brake system. I received 2 master cylinders with different bore sizes is that normal? If yes, which one is for the front and which is for the back.
Hello,
The larger 0.75 is for the front.
My Coupe Build Thread: https://thefactoryfiveforum.com/show...65-Coupe-Build
My Roadster Build Thread: http://thefactoryfiveforum.com/showt...ter-Build-9754
Most likely the problem is with the adjustment of the pump rod length where the piston inside the master cylinder isn't returning to the full out position thus the bleed off hole inside the cylinder isn't being uncovered. Check to see if the rod is loose with the pedal full out. If not, adjust the rod length until there is slight play with the brakes released.
King
