Results 1 to 1 of 1
Thread: Ultra Thermostat Housing Assembly - Cobra Earl
    Banned
    TD Motion has put together a complete Thermostat Housing Assembly Kit part of it derives from the lower Cobra Earl Lower Housing. We purchased the remaining 4 pieces. Quantities are Limited to these at the moment.
    On a good note Earl has been battling Cancer and recent tests show his marker numbers down and below normal!!
    The small block Fords have a lot of issues with getting Air Trapped and not allowing the Air to "Burp" from the Cooling system. Leading to hot spots and fooling the cooling system into thinking its full. This Housing assy will release all the air out of the cooling system. Runs more $$ than a cheap chrome plated steel housing that often - Crack, leak and peel. From an aesthetics Point of View This Assembly looks pretty cool under the Hood !!!
    For more details please check out these Two Links
    https://www.tdmotion.com/product/427...t-housing-kit/
    https://www.tdmotion.com/product/spe...ostat-housing/
    "Ultra Billet Aluminum Thermostat Housing Assy"
    Includes:
    Cobra Early Thermostat Housing
    180 Degree Thermostat
    Gasket
    Hardware
    Mid Housing with the 1.5 Radiator hose outlet,
    Fill Neck
    Billet Aluminum 16lbs Radiator Cap.
    FFR Guys take 5% off the Housing Kit or just the Lower Housing Assembly
    TD Motion is the Parts Division of Engine Factory BTW.
