Thread: Cobra's Earl Front vent ducts
    VeniceCobra's Avatar
    Riverside California
    Pfff, it's hot in there! I'm cooking!
    I have almost everything plan for the ventilation, but I cannot find a part: Cobra's Earl Front vent ducts
    The duct with 2 holes as shown in the pic
    Does anyone get a pair somewhere in their attic?
    Or the complete kit?
    Thank you
    Pittsburgh PA
    I should have a set not being used. Let me check the garage tomorrow and get back to you.
    -Fred
    Quote Originally Posted by FMJ View Post
    -Fred
    Thanks Fred, that will great!
    It looks like an Allstar Racing Products double brake vent that takes a 3" tube.
    If you can't find what you are looking for then consider eyeballing any Dirt Track Parts Website and you will likely locate what you need.
    Good Luck!
    Pittsburgh PA
    Found them...PM me with an address.
    -Fred
    Curmudgeon
    I'm running glass ducts. They are molded in place for a cleaner transition, but are for a bit smaller duct. If you are into fiberglass work I can hook you up with some disposable urethane molds.
    San Diego Ca 92106
    Is there a parts list for the Cobra Earls fresh air system? I'm assuming the front intake, the hose, footwell connection with cable operated closure, and an optional bilge fan. Anything else?
    Quote Originally Posted by mikeinatlanta View Post
    Thank you sir, but I'm gonna go with Cobra's Earl system, as I my change and modify it to my need.
    but again, I appreciate and thank you
    Good Luck!
    Indeed I found couple ones from wallmat (?!?!?0 to summit racing.
    The key word was "Double brake vent"
