Results 1 to 2 of 2
Thread: FF5 wheelspinner assembely
    Dec 2013
    I just received a new set of FF5 knockoff wheels and the question is, Is there a trick to assembling the hub, cover and spinner to the wheel? The hub is not tight enough in the wheel to get it together.
    Tech Manager, FFR
    You could use a couple of very small pieces of double-sided tape or some other small amount of adhesive to hold it in place while you start the thread. Once the spinner's on enough, you can usually hold the stud while you thread it on the rest of the way.
    I'd use a little anti-seize on there and make sure you don't overtighten them.
    Happy Holidays!
    Jason @ FFR
